Quote: the rear r/t badge is designed to fit on the tail panel, it is cut to fit just right
Right, I have it there, with the 2 pegs sticking through the holes I drilled in the tail panel. What I am asking is what holds the pegs in the holes? This was a Coronet 500 panel, but if I remember correctly when I removed the 500 emblem the pegs were basically melted/mushroomed into place.
