A lot of members recomend that I add an alt to my race car. Does anyone make brackets for a RB with a Milodon gear drive and a MSD crank trigger set up? I may be able to move the crank trigger from passengers side to the drivers side with little problem. The oil filter is remote with only oil lines running from oil pump cover.
Also seems that the Toyota alt is prefered by many. What does it come off of?
Thanks,
Brian Dunnigan
