Don't know if this will help, but the fat man fab front stub I used had me measure from the floor to the top of the core support mount before I cut the frame, then when I put their front clip into my frame rails, I just had to jack the front up where their core support was the same height or a little lower than the original core support mount height. Easier to shim the core support up than try to get it to go down.
