Cure time on Omni is 24 hours at 70F. Depends how much filler you need if you need to get to metal. If you can fill with a glazing putty then 80 grit is sufficient for adhesion. Otherwise plan on 24 grit to rough up the metal.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
