thanks for the input i am lookin at the short block as i have a 340 in the car now im told ill need a oil pan & motor mounts i have ebrock heads & intake msd ing system my fly wheel is nutreal balanced these chevy builders i have talked to around here scare me would cost alot more to build this is why im lookin for a short block aready have the parts from the 340
The oil pan that came with my motor is a kevco nice piece it has baffles and a crank scraper built in plus it hold 6 quarts without the filter with plenty of ground and steering clearance in my challenger. Plus 2 drain plugs on to empty the oil and the other to use to gauge if you dipstick is correct.
As for the motor mount 340's and 360's use the same you shouldn't need new ones.
