The 66-67 440's used a pushrod with a different tip. All other 440's used the usual rounded tip, but the 66-67's used a pushrod with a tip that tapers narrower before comming to a point. They also used different lifters for those pushrods. To use any aftermarket cam in a 66-67 440 you must change to the newer style pushrods, summit sells some cheapies.
