Can you post a pic of that insulation in its correct position on the car please?
I had the same question reguarding the cables. Two cables from the passengers side go through the center of the steering colom bracket. The fresh air cable from the drivers side goes up over the top of the colom bracket.(between the bracket and the underside of the cowl)
