Quote: The old direct connection book says that the ball should be 5/16 from the rocker arm.Not all adjusters are the same.I have seen it with my own eyes that when the ball is closer to the rocker;the folcum will be closer to the shaft and will lift the valve more.Its not much but it happens.
nobody is talking lift we are talking geometry
What occurs when you change the adjuster is it starts putting a lot of side load and reducing the lift.. it in i self(adjuster) doesnt change the valve/rocker geometry
