When changing from stock oiling system to an external line system with a swinging pick up, where is the best place to plug the stock pick up port in the block. In the crankcase, where to stock pick up was unscrewed from, or in the block behind the oil pump. Any other modifications need to be done?
Thanks, Brian Dunnigan
