I used that duplicolor spray bomb bedliner to seal up some floor pans after brushing on some primer. It gives a real nice finish but I don't know how durable that stuff really is. Anything without a hardener mixed in prior to application likely won't be as strong. But it won't be any weaker than regular body paint and much easier to touch up. Just a PITA if you ever change your mind and want it gone.
