I see the enlarged mounting holes now slots on the old one. Were they actually needed with the current setup? If the new mount bolts up OK I'd use it.
If not, time to figure out why the slots were needed. Motor mounts slipped? Different transmission X member? Changed transmission type (904-727?)
