Re: Window Net Pictures
[Re: Blucuda413]
#763148
08/02/10 12:03 PM
08/02/10 12:03 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
NHRA RULES SECTION 20.27 Quote:
6:3 WINDOW NET A ribbon-type or SFI Spec 27.1 mesh-type window net is mandatory on any full-bodied car required by the rules to have a roll cage. Window net must be securely mounted on the inside of the roll cage, with the permanent attachment at the bottom. All attachment points must be designed in an attempt to protect the driver and avoid contact with track surface or guardwall. Eyelet clips, dogleash hardware, hose clamps, etc. prohibited . Penetration of webbing, except as performed by manufacturer, prohibited. Any modification to net must be performed by manufacturer. A ribbon type window net does not expire, unless it is torn or battered.
but if you have a cgae and your car is slower than the rules mandate having a cage you can skip the net.
home of the Sox and Martin Hemi Duster
