Thanks for all the tips. I know I'm missing something somewhere. I'm kind of stuck with the converter since I sent the wrong core to be rebuilt and ended up with a 19 spline that I could only find one converter for from Summit. With the AG hood I'm kind of limited on space. I don't know if I could squeeze an RPM Intake in there. I already have a chopped and lowered fiberglass base plate. I think I will check my timing, it may be off also. I quess I should re group and start with all thew simple stuff first before I go and spend a bunch of money.
