Good to know! I guess that would explain some stuff, but yeah, the backfiring through the carb is an issue now? Should I just pull the heads? Can I pull all the rocker gear and look for any tell tale signs of bent stuff? Would my compression have shown 125-140 on all cylinders with a bent valve? Confusing!
