Quote: Mine are angled in the wrong direction...Why would this happen???
Mike, i've had the shackles do this on 2 SS spring installations, it would lift the car so much that the shackles were angled around 1:00 (top) & 7:00 possition, you will need to currect this by adding blocks behind the shackle mounts to get it to at least around 11:00 & 5:00.
Now are you shure you are looking at it right?
75 Duster, 451 10.87 @ 123.58 NA
97 Z28 6sp., 12.01 @ 115 on a 100 shot
71 Swinger. 360 magnum. 12.58 @ 105
78 cutlass, 469 BBC. 12.70 @ 108 on street tires.
http://www.youtube.com/watch?v=Z2kqNmMfheU
