Hey all,
I'm converting an '88 W-150 over to a carb due to wiring issues. Got the tank and lines switched from an '84 D-150 and the wiring from the '86 donor works well with the '88 dash harness.
Anyway did 318-TBI motors come with fuel pump eccentrics on the front of the cam? I'm thinking they probably did but I want to be sure. I put a std. pump on it and it didnt pump. I just want to be sure there is one of those little guys in there. If not I've got a parts 318 with one and a new timing chain!
