there was a gts that a guy had that worked at the chry dealership on katy freeway that got burned in a fire same color as yours he was from up north ohio i think this was around 81 84 ?
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
