The 2 750 dp carbs will work great.Mill choke air horns off,block off power valves sq jet # 80 and you will have it close.
The Tunnel-Ram maybe o'll school but its faster.
I found out the Hard Way the Trick of the week stuff never works. Unless your have extra $$$ to throw away.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
