Thread 2 long bolts like 4 inches long in to the block.Then if you have enough slack in the cooler lines just slide the trans back on the long bolts and undo the flex plate while the trans is supported on the jack.I do it all the time at work when we replace a flex plate.Its tight but it can be done.Then the trans just slides back up on the long bolts.Rocky
Chrysler Firepower
