Quote: Do you know if there would be any info on the radiator core support tag that would designate the decal packages applied to these (or any) trucks? If no build sheet is found to decode or no original decals still present is there any way track info on non-obvious trucks?Packages with specific paint schemes(Palomino,Macho)would be easy to spot even without decals,check paint codes or if any original paint was left in door wells etc..what about the ones that no longer wear their stripes?
to answer your question, yes some of the models had a trim code for the special paint/decals on the core support tag. As well, it denotes the paint coded, which also potentially give away what it is....so long as it still has the core tag...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
