Lookin good Bill. If the AC compressor lines up correctly to use 2 belts as the original does...I'd use them. I've got Classic Air brackets on a small block, and it only uses one belt. It will squeel under load sometimes. Use 2 if you can.
Thanks fellas
JD,
I tried and would prefer 2 belts, BUT the pulley alignment makes that out of the question.It's one belt or nothing.
