i had a similar prolem with my roadrunner....the gauge was for a different ohm range than the sending unit. is it a stock sending unit?
mine was a fuel cell, had to order a different gauge. hope this helps
it happens to the best of us. ill bet the sender is a chevy unit operating at different ohms. get a guage that operates on the ohms that chevy does and your problems will be solved.
71 scamp big block with 915 heads 727 trans
