So if I bought those weights could I use a neutral balance flexplate then weld those weights on my converter to balance it out? I have a 9" PTC 3500 btw.
Heres what you want to do, scout the boneyards for a 360 magnum flexplate with the weights "ON" it, then you can run neutral balanced converters, look at the later blocks (1998-2002), B&M no longer makes the flexpate for the 904 too 360 magnum, just the 727 too 360 magnum, now thats not to say the 727 flexplate won't work .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
