The box can get kinda heavy when you're trying to get it in place while on your back. I've done it on two cars and one thing I did on the second car that helped was I got an extra bolt the same as one of the mounting bolts and cut the head off. I then used this as a locating dowel to get the box in place. I put the remaining two bolts in then switched the dowel for the last bolt. Made the install a whole lot easier IMO.
I just replaced my box, and rather than take the risk of it slipping out of my hand and onto my head while installing it from under the car, I loosely tied a rope to it and had someone 'topside' help haul it into position while I maneuvered it into place and got the bolts in...
David
'69 Dodge Charger R/T
