Maybe we should start calling them TRIBUTE carbs ?
Do you really want to get into this?
They are neither clone or tributes they are modified Edels. to fit the original air cleaners. i was asking if you had an original set of factory 67 "cheater" carbs as they were known that flowed 750 cfms in th smaller bodies back in the day. i assumed that you knew how to read the numbers on them to identify them but maybe not.
Look DONKEY , they are CLONE carbs , they have NO NUMBERS on them , I know the source of them , and I know they are NOT the 67 cheater carbs ... more than likely they are Ebrocks and I hope they work ok, if they don't I'll have to find another old carter AFB 750 like the one I have and have them made into clone , er tribute carbs and off these .
