You might try checking the voltage coming out the back of the alternator. My 65 Valiant had 12.5 at the battery and 14.5 at the alternator. Turns out big voltage drop at the amp gauge in my car but could be anywhere including the bulkhead connector. I also had all the same problems with lights and turn signals that you are having before fixing the amp gauge
