Hey fellas. I was thinking of using my 4.56 gears which have been sitting on shelf for several yrs now. My 74 cuda with a mild 440 has 3.91's in it now. I have a 3600 stall and run a hughes solid cam 252/256 @50 with 572.579 lift ,108lsa. Indy Ez's with Eddy victor Int. My 60 ft is around 1.60 and my eigth is 7.25 and 1/4 of 11.48 at 117. I shift at 6200 and cross line at about 6000. Im using a 28'tire. I figured those 4.56's were too much with that tire. Not sure what to do yet. I mostly drive on street (city drivin though)
Most cars do not see there best ET with a shift point higher then cross rpm.
The only way to find out is try them and different shift/cross rpms.
