It's a 241. I see you have a 241 in your coupe - is yours stock and does it push you coupe along ok?
yes it does when its running,,bought the car done,,long story,,but the motor has some issues,even tho it was a fresh motor when i got the car,, its a 241 030 over,,cam was regroundand is bigger then it should be for a motor of that size,with a 4 BBL carb, 904 tranny with a lock up converter,and 3.23 rear,,plenty of power for a cruiser 18 mpg @ 80 mph,electronic ignition, im hoping to be able to make this motor dependable and fix the things the engine builder didnt do so well,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
