Should be only on the drivers side. If you have trouble let me know and I can send you a picture of
one out of a car.
the driver's side is the side that I can't get the feeler gauge to go down. Drats..
It is almost like it hits that area where the first little pin is on the outer casing.
I remember not having any issues doing the pistol grip in the cuda but this one is a bear. for some reason I thought both sides had to be done. Will try again this evening when it cools off.
