Well my friend no better time than now to learn. With that set-up you are going to start sometime.
Changing jets is easy. Four bolts hold the front carb bowl to the main body/metering block. Remove bolts (drain gas from bowl) and there are your 2 jets sitting there waiting to be changed. Check size and go up 2 sizes and see if that makes a difference.
