what kind of carb?
if it's an edelbrock/carter, you can change the position of the linkage to a hole closer to the body of the carb, that'll give a larger pump shot, if the accelerator pump is working correctly. you should see a solid squirt when snapping the throttle.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
