By the way do you have the vacuum advance on manifold vacuum (by the throttle blades or off of the intake manifold) or ported vacuum?
My vacuum advance is on the manifold vacuum port of the Edelbrock carb.
To the best of my knowledge, this is incorrect. The distributor should be receiving ported vacuum (the smaller port on the left side of the eddy carb base when looking at it from the front)
