At least that's what the shop manual calls it. Anyhow I believe mine is defective, I acquired the trans in a trade and set it on my bench to check out and clean up a bit. That's when I discovered it wouldn't shift, so I pulled the pan and valve body and got the shift lever out. Where the throttle lever shaft is staked to the throttle lever has let loose and the shaft just turns in the lever. Probably need a new one ya? Is this a service part or do I need to find an old trans to cannibalize?
