any thoughts or suggestions
"rotor phasing". Drill a 1/2" hole in the top flat of the dist cap about 2/3 of the way between the center and the #1 terminal and freeze the rotor w your timing light at idle and check rotor phasing. You sure picked a monster for your 1st one
