The silver hood photos appear to show an incorrect pattern, too large and extending past the hood inserts; basically as stated & shown by 68jim, the inserts (scoops) are the rt & lt outer perimeter of the finished blackout, and the line straight across the back and vectored off the front of the scoops are the front & rear edges. Measuring straight from the front, you can see that the angles meet in the center. It's basically a pentastar, which is kind of amusing.
