Could be lots of things.
After checking the basics (trans fluid level, oil level, etc). I would pull the valve covers and look for a loose rocker arm (turn the motor over by hand).
A compression check is worthwhile, but I fear a bearing is going away. You should see metal in the heads and oil if that is the case.
1993 Daytona, 5.50 at 130mph (1/8) 1.19 sixty ft (PG). Link to 572 B1 - Part 1
