Yeah, but you're not the first. The cam is easiest to line dots up when they are together, crank dot at top, cam dot at bottom. They're then next to each other. THAT is when it is set to fire cyl #6. Turn crank one revolution and cam dot will then be straight up, ready to fire cyl #1. Not all v-8's are marked that way, but mopar and chevies are.
