Im starting to run the new brake lines and having trouble locating the right line...
I need a part number for the soft rubber line that comes off the frame or chassis that runs to the Y-Block mounted on the rearend housing. This line is slightly lager than the lines running to each side of the axle off the Y-Block...The small lines are 3/16 and looks like the larger line I need may be 1/8 inch Inverted flare but not 100% sure..
The parts store could only pull up a complete line with the Y block attached for like $40...
I thought I might need a longer than normal line, maybe off a 4x4 truck or something.
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
