I don't think so. normally you have to mess with that valve, but maybe the shock from being knocked around did it. I don't know.
But the symptoms you are describing are exactly what happens when it gets out of adjustment.
to prove it, jack up your car and start it. The wheels should turn all by themselves to the right to lock.
IF it doesn't do that, then it would be something else.
