bottom intake isn w5...wider bolt pattern..other wise they look identical...
would this lead you to believe that you can take a standard LA intake and redrill it ...and it will fit a w5???
The W-5 version would also have to be milled for OEM port alignment.
W-5 heads have raised intake (and exhaust) ports.
