Quote: now my fresh 440 with a high volume pump gets about 8psi hot idle with brad penn 10w30. the oil pressure is responsive as it should be to engine RPM. any ideas?
go w the next thicker grade. Actually if it jumps up immediately when you gun it you are Ok though 8 is getting close to the ragged edge. I'd think loose clearances also, somewhere
