I have a 66 coronet with column shift and have recently bought a whole center console assembly with shifter and all the brackets but dont know exactly where to weld the brackets. I guess what im asking is if someone has there b-body apart with a console shifter and could give me a mesurement where the shifter bracket is welded on, probly from the front of the shifter bracket where 14" on tape mesure in picture to where the top of the trans hump floor and firewall is welded. the rest would be pretty easy to locate since the console screws to the shifter. I have a service manual but it doesnt help much. any help would be greatly appreciated!!
