wrong...different plenum volume. different runners.
you will see a gain over the stock manifold with a performer.
the ld340 is a good intake.
Wrong? Where did I say the plenums were the same? I said as compared to certain manifolds it was more like a stock unit.
mark7171 Well at any point are you going to reply...or do you save that only for an unwarranted attack where you still think you are correct?
Some things are constants around here...
FUEL ECONOMY???
