We get more accurate readings with it in a tube about 18" from exhaust port.
Unfortunately lack of clearance dictates that I cannot mount the sensor in the actual header pipe. I'm just wondering how far from the open collector end can it be before readings will be inaccurate?
thanks for your reply
Yeah, what he said. I just went and looked at the instructions for my AEM and it says 18" from the port, 36" if you expect EG's to be 800 degrees or more.
Mo' Farts
Moderated by "tbagger".
