It appears the wrong year pump is in use, looks to be a Saginaw for a truck w/AC application mid 80's-90's, you need the eariler "bottle" top Saginaw, your brackets appear correct for the Saginaw application,...a Federal or TRW pump requires different brackets
Mike
