I used to use the MP chart but have switched to the manual/visual method. If adjusting intake, bump the remote start switch until the exhaust valve for the same cylinder is significantly depressed then adjust intake. Vica versa for exhaust. For me its easier and faster to go cylinder by cylinder in order.
