does it go away on coast? if so, it's an exhaust leak.
Ok I went out for a run and like I mentioned earlier the tick comes on at about 2000 and I noticed it changes pitch just a little bit. When I let of the gas the sounds does go away as far as I could tell. Tomorrow I'll start checking header gaskets and the collector gaskets too.
Thanks for everyones replys!
