Summit headers $109. They are the same as heddmans I think.
The instruction sheet says you have to remove the starter to install these. Is that so? I had a set of BlackJack headers on a 440 Challenger years ago that burnt up 2 starters because they were so close to it. I finally got sick of it and went to HP manifolds. Pulling the header to change the starter is a pain. Any ideas?
I used a mini starter I jacked the car up. Jacked the drivers side up and they went i from the bottom. Pass side is easy. If you want good headers get a set of hooker super comps
