If you take the intake openning point (keeping in mind 360 degrees rotational angle) and closing point and figure the point inbetween you can find the intake installed centerline. Same with the exhaust. If you have the numbers you can use those to figure it out, just keep in mind TDC = 0. BDC = 180, and do the math accordingly Hope that helps!
