So the cig lighter outlet should only be powered on when the ignition switch is on? If it is on with the switch in the off position is this an indication of a problem with the ignition switch or the cig. lighter? Do I understand you correctly? Thanks! My rear power outlet is only powered with the engine running, and the power outlet on the dash seems to be powered with the ignition in the off position.
